Just for example, I have a vibrating screen and I want to study the relationship between the static friction coefficient and the mass flow velocity (or accumulated mass over time) of the lower layer of the vibrating screen. How can I create a response?
I couldn't find the statistical field I set when setting the cross-section in the data source
In other companies' discrete element software, this can be set through the variable panel and smoothly imported into software similar to Hyperstudy
Here are my source files
