Hi everyone. Today I was about to make a rigid cube rotate around Z axis of global system.
First, I set a master node on the surface of the cube and then made the nodes of this component subordinate to it. Then I exert IMPDISP (ZZ) on this master node.
The problem is, while Radioss completed the task without error, there is no anime output neither iteration record, just like no physical process in the simulation.
What the reason is? It's an urgent issue and could someone help me?
HM file is attached.
