A simple cantilever beam is considered with square cross section. Analytical tip displacement should be 0.108064. Attached is a model with P3_beam elements, this one works perfectly.
However when trying to use P18_INT_BEAM elements instead, it gives a displacement of 0.323… I suspect that the cause is somewhere in the material?
The material goes into plasticity (while it shouldn't). During debugging, the error messages lead me to believe it is incompatible with M1_elast? In order to still get elastic results I tried to elevate the yield point such that the analysis stays within the elastic regime but here I got stuck.
The question: how to configure the P18_INT_BEAM model to get some agreement with the linear elastic hand calculation?
