Why my MotionView flex body node connection cannot be saved? And another question.
User: "Garand"
Altair Community Member
Hello everyone,
I have 2 ploblem in MotionView flex body, they maybe bug.
1 :
Every time I open my model, it shows a error like below. It tells me the connection of a joint to flex body is empty. However, I fixed and saved it every time when I close the model. It just jump back to the old version the next time I open it.
Marker "Leaf2Axle_F_L-Compliant-Joint-Marker J" under "Model-System dual axle suspension-System Rods and Leaf Springs-Leaf Spring Left-Graduated Leaf" points to Flexbody "Housing_Mid" under "Model-System dual axle suspension-System mid axle asm-System housing mid flex", but specifies an invalid node id. Please go into the flexbody panel's node dialog and make sure all connections to flexbody are valid. [General]
I tried move the model to a new path, the problem is the same. In fact, all config in connect node id cannot be saved now, it's always a certain version when opening model. Dose the software save these infommation in a certain place?
Have anyone met the problem before? How can I fix it?
2 :
When I perform "save and run current model" in Run panel, it shows errors like below:
Error evaluating MODEL.sys_susp.sys_Maxle.bsh_bearing_pinions_2.jfloat.node_id....Ignoring illegal override of constant data member. [General]
It appears twice for every Bushing using User subroutine. However, I have not use any jflost marker in defining them. The input of User subroutine is:
USER({bsh_bearing_pinions_2.i.idstring},{bsh_bearing_pinions_2.j.idstring})
Luckily, the simulation can still run, and the result seems normal (also possible that I cannot identify the abnormal). How does it happen? Can I just ignore them?
Thanks for every reply
Garand
1 - 1 of 11
    User: "Praful"
    Hello Garand -
    Would it be possible to share your models and files ?
    I see you mention v2021. Could you upgrade to the latest version ?
    Regards
    Praful
