Process is existing as a dreference error during the sim
User: "JainamShah"
Altair Community Member
class processtest;
  process p[];  event ev[];
  function new();
  p = new[5];
    ev = new[5];
  endfunction
  task start_prcess(int idx,int delay);
    fork
      begin
      $display("starting process for idx=%d tiem: %0t",idx, $time);
    p[idx] = process::self;
     wait(ev[idx].triggered);
      $display("process is done idx=%d time: %0t",idx, $time );
  end
  join_none
endtask
  function void process_accepted(int idx);
  ->ev[idx];
  endfunction
function void print_process_status(int idx);
    process::state pstat;
    pstat = p[idx].status();
  $display("idx=%d process_status=%d", idx,p[idx].status);
  endfunction
endclass
module process_test;
  initial begin
    static processtest pt = new();
  pt.start_prcess(0,100);
pt.start_prcess(1,100);
  pt.start_prcess(2,10);
  pt.start_prcess(3,1000);
  pt.start_prcess(4,200);
     pt.print_process_status(0);
  pt.process_accepted(1);
  endmodule
when I run this code I get following error which I am not able to explain. If I remove the pt.print_process_status(0); then this error goes away
S:Begin run-time elaboration and static initialization...=N:[dumpMXD] preparing MXD dump to 'waves.mxd'.=N:[dump] Dump started at time 0=N:Starting event scheduler...=F:[NullRef] null handle 'p' dereferenced @ testbench \processTest.sv:41:14=N:[dumpMXD] closing MXD dump=T:Simulation terminated due to null handle dereference.=N:Backtrace:
PS: is there a better way to put the code in the question?
1 - 4 of 41
    It is better to attach your source code as files rather than paste their contents as comments.
    Did you look at line 41 of processTest.sv? That's what the error message says:
    Did you initialize 'p'?
    User: "d3jones"
    Subtle point: when you fork…join_none, the children do not start running until the parent blocks. In your code, you have the parent call print_process_status() immediately after forking. If no process has started at that point then the p array will be uninitialized.
    Try adding a #0 just before the call to print_process_status() to see if behavior changes. That will delay the parent into the inactive region, allowing the children to start in the active region and initialize the array.
    User: "JainamShah"
    OP
    Yup this was the case. some other simulator ignored it . Thanks for catching it
    @JainamShah Did d3jones comment resolve your issue? If so, could you please mark it as "Accepted"?
