Hypergraph Line/Complex Plot Chart types: switching between the two
User: "KrisGarner"
Altair Community Member
Description: When loading frequency response function data into either a line chart or complex chart type, if I want to switch between the two I have to reload everything… is it possible to avoid having to reload the data and just (say) hide the phase when switching from complex > line type? Often I want to do some maths on the curves which requires the complex line type, but when creating plot images for reports/emails, I may just want to show the magnitude.
Product/Topic Name : Hypergraph, currently using v2024.1
*Note from Community Team - Once you receive a satisfactory answer on your question, kindly mark your answers as "Accepted" so it can help others with similar problems. Thanks.
1 - 1 of 11
    User: "Shreesha_P"
    Hello KrisGarner,
    Unfortunately currently this is not possible since the line chart and complex chart are treated as two separate sessions. Switching from one to the other will clear all existing data.
    Best Regards,
    Shreesha
    User: "KrisGarner"
    OP
    Hi -thanks for confirming my current understanding. I think this would be a useful enhancement as I hope the use-case as I have described it is clear? (i.e. complex plots for curve calc's and then switch to line plot for ppt). Are Altair working on this / going to consider it?
