I created a cube and i want to make a hole in it. There is any way that i could draw a circle on a sketch on top of my cube, then extrude it down so it became a hole?
Hi @GabrielZumaeta,
I'm sorry, your post has "Inspire" tagged so I assumed that was the intended application.
A similar approach can be taken in HyperMesh, where the hole is cut using the Boolean-Subtract Option after you extrude both shapes.
Hope this helps!
Adam Reid
Simply use the Subtract option when extruding the sketch:
I meant, i am using HyperMesh, there is any function similar there?
Thank you, that was what i was looking for.
