Hello Everyone.
I hope you are doing well.
I used Overlay to get geometry for SPSM with damper barsand then updated the geometry to split the slot into 4 equal sections for a double winding setup. The issue I'm having is that my voltage is not sinusoidal, and the stator coils have very high current.
I noticed that during physics creation, I was getting the message " Warning: the field ' Transient Magnet ' is not set. Check carefully its value before validating the box. "What does it mean, and could it be the issue?
I did my best to get this model running, starting from scratch and building my learning curve with Flux. Any help would be appreciated. The attached project does not have a mesh.
