Hello, I'm trying to use motionview to setup a model to valide the suspension system of car. Is it possible to do that? If you have some idea or you know how to do, pls share to me. Thank you !
Hello @NGUYEN_MINH,
Motionview provides a Vehicle Tools extension, from which you can readily import vehicle models, and modify it to your usecase. You can refer to the following eLearning for the same:
MotionSolve v2023 for Vehicle Modeling Please go through it, I hope this eLearning would help you! BR,
Vishvam
hello Vishvam, Thank you for your response. Now I have to understand all type of joint, motion, and the output in motionview. Do you known where I can find the document which explain all kind of variable in MotionView? Best regards,
Here is an eLearning for basic understanding of Motionview entities like Joints, motions, outputs etc.MotionView/MotionSolve Introduction v2023 eLearning You could also go to File—> Help—> Documentation. Search the required entity, and you will be able find the related documentation.
Refer to the below FAQ page aswell for your reference which might help! Altair MotionView/MotionSolve Frequently Asked Questions
Altair MotionView/MotionSolve FAQ and Model Repository
