From this attached simple probe-fed
patch antenna, I am getting the 3D farfield in postfeko much much below the antenna structure, so I am getting negative value for the gain and directivity. I think there are some issues with the antenna layers/faces; therefore, the radiation field is always below the antenna. Can anybody kindly fix this issue?
Thanks in advance!
