I am using Hyperstudy 2025, Inspire 2025, EDEM 2025 and EDEM-Hyperstudy connector 2025.
I have been using this guide:
In part 2 they created a parameterized stl file that I have done as well. The only difference is that I combined all parts in Inspire so I didn't have to use the mesh lines in the python code because that didn't work for me. So now Hyperstudy creates a new stl file with the new parameters. I have replaced the geometry manually with the new stl file in EDEM and that works but when I try to do it in Hyperstudy as they do with rgconfig.txt it doesn't work and the simulation will not run. If I don't write —rg rgconfig.txt -R in the EDEM opts the simulation will run. When i try to replace geometry with —rg rgconfig.txt -R this comes up in the task_exe_stdout.txt:
"Check the value entered for the element size - couldn't convert to a numberGeometry replacement failed."
Is there a solution for this?
BR
