Hi ,
I'm working on a CFD setup in SimLab involving an MRF (Moving Reference Frame) zone that is a thin solid region. I want to ensure 2 to 3 elements across the thin thickness using Region Mesh Control, while keeping the rest of the domain coarser.
My workflow is:
- Apply Body mesh control for entire MRF & Region Mesh Control to particular region (in the thickness) on the MRF zone(CAD)
- Generate Surface Mesh.
- Then generate Volume Mesh.
However, the fine mesh control seems to apply only to the surface mesh. When I generate the volume mesh, the refinement is not preserved across the thin region.
How can I ensure that my Region Mesh Control is properly reflected in both surface and volume mesh, especially for thin solids like MRF zones?
Thanks & Regards,
Sivaprakash V.
