Hypergraph 2D Plots: Applying a custom function to multiple curves
I have a bunch of test data curves in acceleration (m/S^2) from a UNV file.
I want to convert them to velocity in mm/s to compare with CAE pch file results.
In this case, this is two operations (scale, then integrate).
I general I want to be able to apply any user defined function to curves I have selected to either operate curve-by-curve with the same function, or perhaps calculate a single summary curve from all curves selected.
There are a few options:
Single Curve Math > Integral (to operate curve-by-curve)
Multiple Curve Math (for summary curves)
But these present a short list of limited options.
I understand there is a "StackMath" feature in recent versions, but I can't find any useful help for this, and it is not very intuitive. It also only seems to be supported for CurveXY (i.e. magnitude only) plots, and not complex curve data I am using.
It would be nice to just be able to define a formula that does the job, right?
Can anyone help??
Thanks,
Kristian
@Michael Herve -apologies for name dropping you here, but I've seen your name on similar posts so wondering if you could help or direct me to someone?
Thanks,
Kristian
