For water jet cutter, first stage is water pressing soil, second stage is cutter push soil, then cycle again.First stage requires EDEM-CFD coupling, while second step requires EDEM-FEA explicit dynamic coupling.
- as part of head, water jet spin with it. So CFD should change with FEA cutter head.
- Since there's no three way coupling solution exists in Simlab, is it possible to use load case, do several two way coupling instead? While storage timesteps between these coupling?
