I installed the software of Simlab 2025 with additional files, but when i the software, this error is popped up, and the software is unable to launch.
My first thought would be to uninstall the software, re-download the installer .exe and try again.
Maybe try using the default installation directory (in case you indicated a different location the first time)
If still relevant, please check the path where this installation is done. Could you provide a screenshot?
Is a network drive, OneDrive or some special character in installation path or username there?
