I'm using Motion View 2022.1. I have a multi-body system with a few external forces applied. After simulating the model, in HyperView -> Animation, I tried to plot the force vectors, but they weren't appearing and I got the value: N/A.
The other internal forces in the system appear as vectors.
For the Animation, i load my model in .h3d, and i chose Advanced Result-Math template as i saw in others discussion about this vector problem.
I have three external forces (see image), and only the first one appears as a vector.
However, the other forces are still active; I can see their impact on the movement of my system.
I also selected the first active force and gave it the coordinates and values of the others . It works, so it's not a parameter issue, but perhaps an instance issue with the force object.
Can someone help me with this ?
Best regards
