I’m using PSIM’s TI C2000 library to simulate an F28379D-based control board and need to read a differential voltage at 14-bit resolution. I’ve set up my schematic with the “ADC Module” block, but it cannot be adjusted to:
- Enable differential input mode on a given ADC channel pair
- Select 14-bit resolution (instead of the default 12-bit)
- Route the positive and negative pins (e.g. ADCINA2/ADCINA3) correctly in PSIM
