I have followed the single-phase induction Motor tutorial. Some poor-quality elements occurred, which is why I am obtaining a linear graph for Mean Torque vs. Speed. What should be done to improve the quality of the mentioned elements?
This is the result of Physics Check.
This is the obtained graph.
This is the graph obtained in the tutorial.
What else could be the issue, please provide a solution.
Thankyou
Hi SPB,
Thank you for contacting Altair forum.
The deviation in result you obtained is not with respect to poor quality mesh elements, since they are less than 0.7%. If you would like decrease still the poor quality, you can adjust the settings in Aided mesh options.
May be we need to check your model with respect to physics you have assigned for the model.
If you are working on a specific project, please do contact Altair support.
Thanks
Karun
