Dear Altair Support Team,
I am designing a monocone antenna in FEKO using a surface-based cone structure with a parabolic top cap, where the feed is implemented via a vertical wire connected from the cone tip to ground. While the geometry appears correct and the simulation runs, I am encountering a significant issue: current does not propagate through the cone body. Despite the wire feed connection, the cone surface does not behave as an electrically continuous path, and no meaningful current distribution or radiation is observed across the cone. I suspect the problem arises from the interface between the wire and the surface-based cone structure, which may not be electrically connected in the simulation. I would like to know how to properly model the feed connection so that current can flow across the entire cone surface. Is there a recommended method in FEKO to ensure electrical continuity between wire elements and surface geometries? Any guidance on correctly establishing this junction and resolving the feed issue would be greatly appreciated. I attached the editfeko, Postfeko file and also feed connection problem image.
