Overview:
When using the Relative Wear Model, EDEM calculates two geometry custom properties: Normal Cumulative Contact Energy and Tangential Cumulative Contact Energy. This script uses EDEMpy to add these two properties together and creates a new geometry custom property called Total Cumulative Contact Energy
Prerequisite:
In order to use the script, the Relative Wear model must have been used in the simulation.
Usage/Installation Instructions:
To run the script, place it in the same folder as your dem file. Then, specify the path to your deck in line 53 and the geometry name in line 54.
Post-Requisite:
Release Version:
