Please, can someone help me with the link to find the list of all the Tutorials available for EDEM?
Thank you
Hi @Johnson,
Tutorials for EDEM can be found directory in the Help Documentation
Additional training can be found online through our eLearning resources.
Hope this helps!
Adam Reid
Thank you. Adam.
But I could not access the Help documentation. Below is the message popping up, and when I continued to the external site, it was not working. But the e-learning link is working fine.
From an open session of EDEM, simply press F1 to access the Help or use the Help button in the ribbon:
Thank you, Adam
Not a problem.
To help other Users find this solution quickly, please make sure to mark one of the above responses as Correct.
Thanks,
