Is it possible to perform a topology optimization (obj=min mass) by setting as constraint the difference between two nodes? I understood that I have to use a DRESP2 and an dequation to link the nodes: the function I wrote is f(x1,x2)=x1-x2 I have many couples of nodes to monitor. If there is an example/tutorial how to write DTABLE and what I have to put as DESVAR will be very useful.
Thank you!
Adele
