I am currently using the feature to add a non-radiating network to my simulation.
I can create a simple spice net-list to implement my network, but I don't know how to parametrize it. I would need that to conduct parameter sweeps and optimizations.
The model is simple enough that I can also input a formula for the z-network, but here I can not find a way to make it frequency dependent and parametrized.
I can generate the z2p parameters externally as a file which would be frequency dependent, but not parametrized.
I can write a parametrized variable in the z-parameter section, but it will not be frequency dependent.
