I'm working on a project that involves performing the Double Lane Change event. After building the vehicle model, I made sure there were no errors, and then I configured the Altair Driver and the event with the specific parameters I needed.
However, when I click Run, the simulation stops immediately before starting, showing an error message in the log "ERRMES:USER [349001]" "Signal DIS not found".
How can I fix it?
Thank you very much in advance!
