Hi Altair, I've tried to use HyperStudy to do Simlab DoE. However, when I recorded the script in Simlab and ran in HyperStudy, I found that non-meshed coils are not selected.
Is there anyway to solve the problem? Best regards, LeonLin
Hi @Leon Lin,
Can you provide the task_exe_stdout & task_exe_stderr files from the HyperStudy setup folder i.e. m_1 folder?
Else, from which file have you confirmed the reason as 'non-meshed coils are not selected', kindly clarify.
We would require more information to check if it is a HyperStudy or SimLab issue.
Also, let us know the version of both HyperStudy & SimLab. being used.
Many thanks.
Kind Regards
Garima Singh
