I have Question regarding the Calculation of Interaction Effects in Hyperstudy 2024.1.
I ran a fractional Factorial Screening DOE with Resolution IV, with 10 Parameters and 24 total runs.
As far as i know "Resolution IV" means, that the Main Effects are not confounded with Two Factor Interaction, so they can be distinguished from each other. Two Factor Interactions are confounded with each other. For example: the calculated Effect for AB might be the same as BC. If you want to find out the exact Effects for AB or BC, you might need to do more runs focused on these parameters.
But if i check the Interaction results from the DOE i made, then does every Interaction have a different Effect Value. No Effect occurs two times, so there is no confounding.
I am a bit confused by this. How is Hyperstudy able two calculate exact Effects for each Interaction, without doing more runs?
Thank you in Advance
Ludger
