Hi
I have been trying to model the crushing failure of composites with Radioss under a pin-loaded setup. I use MATLAW 25 with the CRASURV formulation for the composite. I don't use any additional failure criteria. I have established Type 7 contact between my pin and composite. When I try to run it,
I either get Node xxxx deactivated from the interface error, or I get Time step less or equal zero error
I have attached my model files. Any help on this will be greatly appreciated.
