Is it possible to model a pile with reduced diameter at tip socketed into bedrock, say a 3 m diameter pile to bedrock with 2.7 m diameter rock socket. I tried to change the section using the member spreadsheet but the section cannot be edited, and there is no way to combine the two sections in the soil profile window. Is there a way to do this with the script editor ?
