NLFE Cable through python script?
User: "Jeeb"
Altair Community Member
Hey,
I am currently working with NLFE Cable Bodies in MotionView and am quite pleased with them.
I now want to generate them through a python script, since my final model will be quite large with lots elements that will have to be scripted. However I can't seem find a corresponding comand or way to do it.
Maybe I'm missing something or perhaps it's not possible.
Any help will be greatly appreciated.
Kind regards
J
(2022.3)
1 - 1 of 11
    User: "Orestis_YB"
    Accepted Answer
    Hello @Jeeb,
    to create a NLFE Body using python command you need to use mview.LDBody(). Here is a script where I am creating 50 Points to define a NLFE rod of diameter 1mm
    from hw import mview
    def createPoint(idx,dx,sys,offset):
    return mview.Point(parent = sys ,name='p_' + str(idx), label='Point ' + str(idx), x = offset + idx * dx)
    N_beam = 50
    d_beam = 5
    #points for nlfe
    p_nlfe = [createPoint(num,d_beam,'MODEL',0) for num in range(N_beam)]
    #NLFE Body
    nlfe=mview.LDBody(parent = 'MODEL', points = p_nlfe, name = "nlfe1", label = "NLFE Beam 1")
    nlfe.cross_section_type = 'Rod'
    nlfe.dim1_start = 1
    nlfe.rayleigh_damping = 0.01
    Hope this helps!
    Best regards,
    Orestes
