Is it possible to copy and paste the operators from another process? Thanks for any advice!
I've tested this, and it works on my machine. Note that having two instances of the same version of AI Studio isn't supported, so the use case would be opening a new process within the same instance, and pasting the selected operators in the new process.
Thanks,
Roland
Hi @hmhsing,
Yes, it is possible. You can use Ctrl + C and Ctrl + V, or find the options under right-click.
I tried but failed. I opened two RM processes and tried to copy and paste the operators between them (not within one process). Thanks for the help!
I got it, thanks a lot!
