how to define the hydrostatic pressure of the liquid in the tank with linear static problems (use Optistruct solver)?
Have a look at the following discussion:
a tank modeled with shell elements
Hi there,
If I understand well, you would like to take into account the pressure produced by the volume of fluid through the height distribution of density; it that is the correct assumption, then, you can easily account for that by activating the gravity effects in the CFD solver and declaring an acceleration of gravity of 9.81 m/(s^2)
