hello i am trying to activate cuda solver on altair edem 2025 on red hat linux
But i keep getting this error.
Please tell me how to fix this
The device has this version of cuda
please tell me which driver should i install and how?
HI,
EDEM is not showing any Nvidia GPU card so it maybe that your system doesn't have a Nvidia GPU installed? The Intel graphics doesn't support CUDA which is required for EDEM GPU.
I would recommend confirming the GPU installed, for the drivers the Nvidia site is best:
https://www.nvidia.com/en-us/drivers/
Regards
Stephen
NVIDIA graphic card is present on the mcn
Hi Stephen, please tell me this. Will the EDEMsolver work with a computer that uses an AMD graphics card?
No for GPU solver it's Nvidia CUDA only. NVidia Gforce RTX 2070 should be compatible, drivers would be available via the Nvidia site. When EDEM checks if a GPU is compatible it runs nvidia-smi command, which is useful to check as if that command doesn't run then there would be some issue with the GPU install.
You would be able to run CPU with AMD but not GPU.
