I am facing segmentation error whenever I use quick selection through Alt+by face/path or any other option and also if I try to select manually. This completely affect productivity and the flow of work. Altair employees suggested me to run the batch file from the C drive, Yes I have run the same, but nothing has changed. Again and again I am facing the same issue whenever I choose elements through quick selection mode that is also in the particular portion, I have check duplicates as well, as Altair employees asked me to check duplicates of elements.
It went after deleting the particular portion of the mesh which took me to mesh more 3 hrs. Kindly do check this option and provide proper solution and upgrade this….
I have informed this to Altair since I am using HM 2024 version, Currently I am using 2025 version which is recently launched …… In 2025 also same error/issue I am facing.
