We’re building a multibody dynamics (MBD) model of our Formula Student electric vehicle using MotionView  with the FSAE vehicle library. We’ve successfully removed the default internal combustion powertrain and replaced it with the electric powertrain setup from the commercial vehicle example model.
What we’re trying to achieve:
We want to simulate dynamic events (e.g., constant radius, acceleration) using tire parameters based on our actual FSAE tire data. Our goal is to replace the default example tire data with our own fitted coefficients, calculated using the Magic Formula based on data from the FSAE TTC.
What we've tried:
- Generated custom MF-Tyre data using a self-developed MATLAB fitting tool.
 - Initially tried to load this as a new tire file but ran into the error:
"Unknown PROPERTY_FILE_FORMAT", due to missing required chunk:
PROPERTY_FILE_FORMAT = 'SWIFT-TYRE'
FUNCTION_NAME = 'tnodelft::DTYRE'
ROAD_SOURCE = 'TNO'
N_TIRE_STATES = 5
USE_MODE = 114
HMAX_LOCAL = 2.5E-4
SWITCH_INTEG = 0.1 - As a workaround, we manually edited the default example tire files and replaced the coefficients with our own.
 - After this, the model loads and runs, but the simulation fails partway through the dynamic events
Is manually editing default MF-Tyre files the recommended approach, or is there a more robust method to import our custom tire data?
Are there any best practices for ensuring stability and convergence in simulations using edited tire data?
Have we possibly missed any available FSAE-specific tire templates or documentation for working with TTC-derived models?
Is there a way to validate that the modified tire file is being parsed correctly by MotionSolve?
Any guidance or sample FSAE tire integration practices would be very helpful. We’d be happy to share snippets of our tire data or the modified tire file if needed.
