How to update the path of motionsolve bin directory?
sudo
sudo Altair Community Member
I am getting this error when running a simulation in twin activate:
"Unable to load MotionSolve interface dll during block initialization"
I tried to run this command in command window:
GetMotionSolveBinDirectory()
It outputs this:
ans = C:\Program Files\Altair\2024.1\hwsolvers\motionsolve\bin\win64
It is pointing to the version 2024 but I have updated my motionsolve to version 2025 and the bin folder is now located inside the 2025 directory.
How can I update and tell twin activate that the bin directory of motionsolve is at
C:\Program Files\Altair\2025\hwsolvers\motionsolve\bin\win64 ?
Best Answer
  • Vishvam
    Vishvam
    Answer ✓
    Hello @sudo
    I hope you have installed same version MotionSolve/MotionView and in Activate make sure you have setup the MS/MV path in File->Preference->path. Here is the snapshot
    It can be the 2025 version path in your case.
    Hope this helps!
  • Vishvam
    Vishvam
    Answer ✓
    Hello @sudo
    Hope this helps!
  • sudo
    Thanks @Vishvam
