Hello everyone,
I am performing a non linear analysis on a motor assembly. It consists of two loadsteps connected using CNTNLSUB(SCID)
- Intereference fit between the stator and the housing
- A moment applied to simulate the applied torque in the motor
I have to run the interference fit load step with non linear contact and inertia relief. Can I use the INREL, - 2 along with IR4NLCON to get the automatic boundary conditons for the interference fit. Followed by a constraint (SPC) and moment. However, when the inertia relief is selected, will it be carried forward to the next loadcase as well? Any help to setup this model is deeply appreciated as I have been struggling from a few days.
Thanks and regards
