I want to use the output datasets from proc optimalbin as input to woe encoding data prior to training a logistic model. I also need to use this for woe encoding incoming data for to prepare it for scoring using the logistic regression scorecode
Has anyone developed code to process the output datasets from proc optimalbin to generate if then else code or proc sql case statement code to create new variables by using the bin boundaries and the stats for each bin.
Any code you are willing to share ?
