License Error
I'm using local license. When i tried to open feko gives me this error.
SECFEKO Version 14.0.432-58 from 2016-09-06
(compiled for target PC_WIN64_EM64T_MKL, 64 bit)
ERROR 9161:
An error occurred while checking out a licence
Altair License Manager: License error
Feature: GlobalZoneEU
Error Code: 51
Error Description:
[LOCAL] C:\Program Files\Altair\14.0\security\altair_lic.dat - (Err: 51) Unable to use network license as a local license
Feature: FEKOGUI
Error Code: 51
Error Description:
License Path: C:\Program Files\Altair\14.0\security\altair_lic.dat
How can i fix this problem?
.... Unable to use network license as a local license
I think you have to setup a network license server for that. Have a look at 'Altair License Management System'
0 -
I already have network license server. I reinstall it now give me this error.
SECFEKO Version 14.0.420-51 from 2016-05-18
(compiled for target PC_WIN64_EM64T_MKL, 64 bit)ERROR 9161:
Altair License Manager: License errorFeature: GlobalZoneEU
Error Code: 17
Error Description:
[LOCAL] C:\Program Files\Altair\14.0\security\altair_lic.dat - (Err: 6) Unable to read file
[NETWORK] 6200@10.17.212.58 - (Err: 17) Request for more licenses than available on license serverFeature: FEKOGUI
Error Code: 9
Error Description:
[NETWORK] 6200@10.17.212.58 - (Err: 9) Feature not foundLicense Path: 6200@10.17.212.58;C:\Program Files\Altair\14.0\security\altair_lic.dat
Used licence file with path:
'C:\Program Files\Altair\14.0\feko\license\secfeko.dat'Used licence number: Not available
Creation date and time of the licence file: Not availableMachine codes for host 'BLG-BB05549':
Not available0 -
Are you sure that your PC can ping license server? Is there 'firewall' or something between?
0 -
Yes i am. There is firewall but i give it permission and also try to close but nothing changed.
0 -
Have a look at server log to check if the client has requested a license? Check also if you have the needed feature on server.
0 -
ERROR 9161:
Error Code: 51
Error Description:
Feature: FEKOGUI
Error Code: 51
Error Description:
After downloading the license file, rename it to altair_lic.dat and place the same in the <installation directory>/security folder
If you have already done the above and still face the error, Use windows folder options / view > display file name extensions, to make sure the file is named altair_lic.dat and not altair_lic.dat.dat,You need to confirm if the Ethernet address in the license file is the correct one and matches the one in your machine.
When you open the license file in a text editor you will see an Ethernet address there in a line that says 'ETHERNET =
The Ethernet ID is the ID of your machine which is exactly 12 hexadecimal numbers. For example D4WRF478F398
Run ipconfig/all in command window and check for physical address under Ethernet adapter local area connection:
The listed physical address under Ethernet adapter local area connection should be used to generate the license file, if there is no listing of Ethernet adapter local area connection, the address under Wireless Adapter LAN Wifi must be used.
That means if the address provided as above does not match the one in the license file, please request for the license file again with the correct Ethernet ID here https://studentedition.altair.com/
0 -
The writer produced an excellent paper, I am very happy with the service from expert writers!! I recommended it to everyone I know!
Awesome job!! Thank you so much!!
0 -
What's up, this weekend is fastidious in favor of me,
since this occasion i am reading this fantastic informative
post here at my home.
check my blog
check my blog
http://booklikes.com/0 -
I like the valuable info you supply for our articles.
I will bookmark your weblpg and take a look at once more right here regularly.
I'm moderatel sure I will be told a lot of new stuff proper right here!
Goodd luck foor tthe following!
http://site-2890895-7467-6692.mystrikingly.com/blog/research-paper-writing-services-in-india
write my essay
write my essay
http://site-2957518-1595-2102.mystrikingly.com/blog/professional-academic-writing-service0 -
Hello, I think your site might be having browser compatibility issues.
When I look at yor blog in Ie, it looks fine but when opening
in Internet Explorer, it has some overlapping.
Ijust wanted to give you a quick heads up! Other then that, terrific blog!
http://site-2892927-1756-3890.mystrikingly.com/
write my research paper
https://generalessaywriting7156.weebly.com/0 -
Actually when someone doesn't be aware of afterward its up to other viewers
that they will assist, so heree it takes place.
https://writeessaysforme.info
paper writing help
paper writing help
https://persuasiveessays.info0 -
It's going to be end of mine day, but before end
I am reading this impressive article to improve my knowledge.
https://comprarcialis5mgonline.com/marca-cialis-professional-20-mg.html
cialis brand online australia0 -
Today, I went to tthe beach front with my kids. I
foud a sea shell and gave it to mmy 4 year old daughter andd said 'You can hear the ocean if you put this to your ear.'
She put the shell too her ear and screamed.
There wass a hermit cra insside and it pinched her ear.
She never wants to ggo back! LoL I know this is entirely
off topic but I haad to tell someone!
http://site-2963089-7965-9177.mystrikingly.com/blog/essays-on-music-roland
college paper writing service
https://helpmewriteapaper434.blogspot.com/2020/09/nothing-found-for-buy-essay-papers-cheap.html0
