Hello everyone,
Wenn I open the hyperwork, it Displays the error 9 and my host id and the .dat file ist in the following. Can someone help me?
thanks a lot!
Can you please send the entire output of ipconfig/all
Run ipconfig/all in command window and check for physical address under Ethernet adapter local area connection:
The listed physical address under Ethernet adapter local area connection should be used to generate the license file, if there is no listing of Ethernet adapter local area connection, the address under Wireless Adapter LAN Wifi must be used.
Which one ist the real Adress? You mean this?
Which one ist the real Adress? You mean this? <?xml version="1.0" encoding="UTF-8"?>
Hi mary
This is correct. You can reapply for license with this above obtained physical address.
OK, thank you!
