Dear all, I'm working under Linux environment and I'm not root on this workstation. In order to check the conformity of the instation of Physics AI 2025, I would like to know if there are command for IPython to check the versions of libraries CUDA and cuDNN which are written at https://help.altair.com/hwdesktop/hwx/topics/reference/extensions/faq_r.htm?zoom_highlight=CUDA+version
Some command as efficient as import tensorflow tensorflow.config.list_logical_device('GPU')
Thanks in advance Steeve
you should try :
nvcc --version
Thank Adriano but my environment is Linux …
despite using windows poweshell, you could just type this into your linux terminal to get the same..
Yes. This is answering about CUDA version. But not about cuDNN version.
In addition, I highlight you I really desire some IPython instructions.
