I would like to create a simulation of a rigid body floating on the water surface or moving through the water. I'm planning to use the Passive Rigid Body feature for testing. I have currently input the initial velocity and constant speed, but the log file shows the following error:
Error: [EIO95] Cannot find/open the preset time dependent linear velocity file (prbcon_linvel_f_c) "" for passive rigid body motion 1.
Do I need to import any additional files, or are there other settings required?
If anyone knows, please reply. Thank you!
