🎉Community Raffle - Win $25
Join and Win
How to connect a feed to a Polygon (PM or PY) in EDITFEKO?
User: "Sungkyun_Lim"
Altair Community Member
I have tried making a wire segment that feeds to a polygon antenna design and I have also tried using a polygon feed to provide the source, but neither are supplying any power to the antenna design.
The only voltage source I can get to work is the Voltage on Segment (A1), but I am not able to get the Voltage on Edge (AE) or Geometry Source (AT) working when I try making a feed using the same polygon corners design.
I'm not sure how or what to continue. And any help would be greatly appreciated.
1 - 1 of 11
    User: "Jaehoon"
    Dear SungKyun,
    I think you need to make sure to connect your feeder geometry to your polygon antenna and need some ground if the antenna is a monopole-type.
    Could you share you Feko model here for me to check?
    Best regards,
    Jaehoon
