hi,
Let's consider a system where two plates (made of any material, with given dimensions) are placed with an EPDM foam sandwiched between them. One plate is fixed, while a force of 50 N is applied to the other plate. I want to determine the displacement (or compression) of the foam from its original shape due to the applied force.
Since I am new to this type of non linear analysis in optistruct, could you guide me step by step on how to perform a proper analysis?
