Hi, i got the next error:
Warning: Maximum step-size values are not equal in MotionSolve and Activate models: 0.01 vs 0.07 . ( 0 )
Block(s): MotionSolve
Model: Inverted_Pendulum_Tutorial
Warning: Final times are not equal in MotionSolve (5) and Activate (7) models. Activate time will be used. ( 0 )
Warning: Relative error tolerance values are not equal in MotionSolve and Activate models: 0.001 vs 1e-06 ( 0 )
Error: ERROR: Failed in StartMSolveThread!(MS license check failed)
( 100 )
when runing this tutorial:Co-Simulation with MotionSolve (Inverted_Pendulum_Tutorial.scm; Inverted_Pendulum_Tutorial.mdl)
I already set the license environment variable: ALTAIR_LICENSE_PATH to altair_lic.dat license in Documents
I already set paths in preferences:
motion view : C:/Program Files/Altair/2017.2-edu/hw/bin/win64
motion solve: C:/Program Files/Altair/2017.2-edu/hwsolvers/motionsolve/bin/win64
motion solve license: C:/Program Files/Altair/2017.2-edu/hwsolvers/common/bin/win64
python : C:/Program Files/Altair/2017.2-edu/hwsolvers/common/python/python27/win64
also i try: admin run, install c++ visual studio
note: i can acces motion view(and loads correctly the pendulum) from the parameters of motion solve block
Altair Active Professional edition with student license, currently installed [Altair HyperWorks 2017.2 Studen Edtion, Activate 2019, Compose 2019, inspire 2019]
Thanks in advance
