I am wondering if there is a way to perform a parametric altitude scan in winprop and automatically retrieve the analysis rasters output.
Many thanks,
Nicolo
If you want to obtain results at multiple heights, you can type all those heights in the Prediction Height specification under Edit Project Parameter > Simulation tab.
Other than that, WinProp is not really designed for automatic parametric sweeps.
Many thanks for your answer.
Interesting way to do it, I would have never guessed it :)
I will try that out.
Cheers
