*** FATAL ERROR # 9174 ***
Hi everyone,
I am trying to run the optistruct solver script on a linux cluster machine, however i keep getting the error below. I have attached the output file as well as copied the contents of the script file i am using to run the optistruct script.
I added the path to the Radflex license file as you can see below, yet it's still not working.
Please help.
Thank you,
Mohamed
Error message:
*** Error starting Radflex licensing utility.
*** Please check RADFLEX_PATH env variable.
*** License checkout could not be initialized.
Contents of run.sh file i am using to run the script in Linux:
#!/bin/bash
$ -S /bin/bash
$ -V
# Where we will make our temporary directory.
BASE='/tmp'
# Put your Job commands here.
# Work from submission directory
$ -cwd
# Defining output and error file
$ -o output.file
$ -e error.file
export ALTAIR_HOME=/usr/local/altair/14.0/altair
export RADFLEX_PATH=/usr/local/altair/14.0/altair/hwsolvers/common/bin/linux64
#export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/altair/14.0/altair/hwsolvers/optistruct/bin/linux64:/usr/local/altair/14.0/altair/hwsolvers/common/bin/linux64
export ALTAIR_LICENSE_PATH=6200@XXXXXXXXX
# your command to run the altair solver
/usr/local/altair/14.0/altair/hwsolvers/scripts/optistruct block.fem -nt 4
For the Radflex error please set up Environment variables
The problem is with respect to LD_LIBRARY_PATH setting and RADFLEX file.
Please export the below variables in your Linux environment in /etc/profile or ~/.bashrc file and this should sort out the problem.
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH: /13.0/altair/hwsolvers/optistruct/bin/linux64:/13.0/altair/hwsolvers/common/bin/linux64/
export RADFLEX_PATH=/13.0/altair/hwsolvers/common/bin/linux64
