Hi Experts,
I have an aircraft C-130 model (attached image). The model is failing during the union process. Could anyone suggest how to resolve this issue so that it can proceed successfully?
Thank you in advance for your help!
Hi @Sunanda ,
Which version are you on? it seems you are using quite an old one.
Can you please share your model .cfx so that we can investigate further?
Thank you,
Zeina
HI Zeina,
Thank you for your response. Here is the stp file of the Aircra. Pls check it, and if you are able to fix it that would be a great help for me.
Thanks
Sunanda
Thank you again. It is Feko 2021 version.
I have attached cfx file here. . The zip folder here. Pls unzip the folder and check the modal pls. The modal is fail to union operation in feko. So kindly check where the problem is in the model
Do you have any update for the modal?
Thank you
The model seems to have a lot of assembly groups and some faces are creating errors while unioning. I suggest you union the parts one by one, and see which part/parts of the geometry is causing the error. You can also use the Repair Part feature or other Repare options when you get error in a union for a given geometry part.
On the other hand, if you have access to the original CAD (outside of FEko), you can try to export it under a different file type and test importing it into Feko again.
Best Regards,
Thank you for your response. I am a new user in Feko. I am not introducing Repair Partfeature or other Repare options. Do you have any manual or tutorial for that ?
Repair Part
REgards
SR
Sure, they are available under the Transform menu, in the Repair Group:
You can find more information about each one in the User Guide.
Best,
May I ask few more issues in feko simulation?
Instead of a full array. I would like to replace a farfield source setup on a plane, but there also showing some mesh error . Can I share you details hor to fix that mesh error?
