Ethernet adaptor
Altair Forum User
Altair Forum User
My laptop doesnt have an ethernet port . which ID should i use???
Microsoft Windows [Version 10.0.18362.720]
(c) 2019 Microsoft Corporation. All rights reserved.
C:\Users\hp>ipconfig/all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : RATTAN-PC
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Local Area Connection* 1:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
   Physical Address. . . . . . . . . : B0-35-9F-54-3F-68
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 12:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
   Physical Address. . . . . . . . . : B2-35-9F-54-3F-67
   DHCP Enabled. . . . . . . . . . . : No
Wireless LAN adapter Wi-Fi:
   Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 3168
   Physical Address. . . . . . . . . : B0-35-9F-54-3F-67
   Link-local IPv6 Address . . . . . : fe80::1c34:dfd4:dbe4:71c%19(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.88.52(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : 16 April 2020 12:06:48
   Lease Expires . . . . . . . . . . : 16 April 2020 13:16:49
   Default Gateway . . . . . . . . . : 192.168.88.1
   DHCP Server . . . . . . . . . . . : 192.168.88.1
   DHCPv6 IAID . . . . . . . . . . . : 128988575
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-22-E8-EB-ED-B0-35-9F-54-3F-67
   DNS Servers . . . . . . . . . . . : 8.8.4.4
                                       8.8.8.8
   NetBIOS over Tcpip. . . . . . . . : Enabled
C:\Users\hp>
  • QuyNguyenDai
    QuyNguyenDai Altair Community Member
    edited April 2020
    You can use MAC of Wireless adapter Wifi
  • Koushik Chandrashekhar_21806
    edited May 2020
    Hi Rajiv,
    The listed physical address under Ethernet adapter local area connection should be used to generate the license file. If there is no listing of Ethernet adapter local area connection, the physical address under Wireless Adapter LAN Wifi must be used.
