How to control force in simlab based on monitored element force?
For example, I have a column like this:
While pressure is from environment, and the structure is already determined, I want to control the compression F between two plates to control the expansion or contraction of this element, based on the distance between two plates.
How can I program on this force and realize force control based on environment? (in simlab-optistruct explicit solver)
