Hi alex2106
Can you please explain what error are you facing?
I launched CADFEKO. but then see this window, *.ini file not writeble
Try these suggestions. It should possibly help you.
1). Do you have Administration rights for your computer because, if not, your computer may be blocking any changes to files. Install the program with the administrator account. 2). If you have Admin rights, then right click on the cadfeko.ini file (in the location you gave) and then leftclick on properties. Make sure there's no tick next to the 'Read Only' attributes box, if this is ticked remove it. 3). If none of the above works it may be a corrupt cadfeko.ini file and may be better to do a fresh download and install again.
Thanks
